Robust Adaptive Segmentation of 3D Medical Images with Level Sets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2000
This paper is concerned with the use of the Level Set formalism to segment anatomical structures in 3D medical images (ultrasound or magnetic resonance images). A closed 3D surface propagates towards the desired boundaries through the iterative evolution of a 4D implicit function. The major contribution of this work is the design of a robust evolution model based on adaptive parameters depending on the data. First the step size and the external propagation force factor, both usually predetermined constants, are automatically computed at each iteration. Additionally, region-based information, rather than spatial image gradient, is exploited by estimating intensity probability density functions over the image. As a result, the method can be applied to various kinds of data. Quantitative and qualitative results on brain MR images and 3D echographies of carotid arteries are reported and discussed.
RR-4071.pdf (894.28 Ko) Télécharger le fichier
inria-00072562 , version 1 (24-05-2006)
  • HAL Id : inria-00072562 , version 1
Caroline Baillard, Christian Barillot, Patrick Bouthemy. Robust Adaptive Segmentation of 3D Medical Images with Level Sets. [Research Report] RR-4071, INRIA. 2000. ⟨inria-00072562⟩
216 Consultations
349 Téléchargements
