Coupling Time of a (Max,Plus) Matrix - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2000
Anne Bouillard
Bruno Gaujal
In this note, we give a bound on the coupling time of an irreducible (max,plus) linear system $X(n) = A \otimes X(n-1)$ with its pseudo-periodic regime. This bounds uses a decomposition of the matrix $A$ into its critical part $A_c$ and its non-critical part $B$, as well as the maximal average weight of a circuit in $B$, which could be seen as the counterpart of the second largest eigenvalue in the classical linear case.
Autre [cs.OH]
RR-4068.pdf (228.75 Ko) Télécharger le fichier
inria-00072568 , version 1 (24-05-2006)
  • HAL Id : inria-00072568 , version 1
Anne Bouillard, Bruno Gaujal. Coupling Time of a (Max,Plus) Matrix. [Research Report] RR-4068, INRIA. 2000. ⟨inria-00072568⟩
256 Consultations
206 Téléchargements
