On a Coverage Process Ranging from the Boolean Model to the Poisson Voronoi Tessellation With Applications to Wireless Communications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2000
François Baccelli
Bartlomiej Blaszczyszyn
  • Fonction : Auteur
We define and analyze a random coverage process of the $d$-dimensional Euclidian space which allows one to describe a continuous spectrum that ranges from the Boolean model to the Poisson-Voronoi tessellation to the Johnson-Mehl model. Like for the Boolean model, the minimal stochastic setting consists of a Poisson point process on this Euclidian space and a sequence of real valued random variables considered as marks of this point process. In this coverage process, the cell attached to a point is defined as the region of the space where the effect of the mark of this point exceeds an affine function of the cumulated effect of all marks. This cumulated effect is defined as the shot noise process associated with the marked point process. In addition to analyzing and visualizing this continuum, we study various basic properties of the coverage process such as the probability that a point or a pair of points be covered by a typical cell. We also determine the distribution of the number of cells which cover a given point, and show how to provide deterministic bounds on this number. Finally, we also analyze convergence properties of the coverage process using the framework of closed sets, and its differentiability properties using perturbation analysis. Our results require a pathwise continuity property for the shot noise process for which we provide sufficient conditions. The model in question stems from wireless communications where several antennas share the same (or different but interfering) channel(s). In this case, the area where the signal of a given antenna can be received is the area where the signal to interference ratio is large enough. We describe this class of problems in detail in the paper. The obtained results allow one to compute quantities of practical interest within this setting: for instance the \it outage probability is obtained as the complement of the volume fraction; the law of the number of cells covering a point allows one to characterize handover strategies etc.
RR-4019.pdf (926.49 Ko) Télécharger le fichier
inria-00072622 , version 1 (24-05-2006)
  • HAL Id : inria-00072622 , version 1
François Baccelli, Bartlomiej Blaszczyszyn. On a Coverage Process Ranging from the Boolean Model to the Poisson Voronoi Tessellation With Applications to Wireless Communications. RR-4019, INRIA. 2000. ⟨inria-00072622⟩
397 Consultations
706 Téléchargements
