Lyapunov Equation for the Stability of 2-D Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2000
In this report, an analogue of the characterization of asymptotic stability of the rational systems by the solvability of associated Lyapunov equation is proposed for 2-D systems. It is shown that internal stability of Roesser model is equivalent to the feasibility of some linear matrix inequality (LMI), related to quadratic Lyapunov functions.
RR-4014.pdf (225.74 Ko) Télécharger le fichier
inria-00072627 , version 1 (24-05-2006)
  • HAL Id : inria-00072627 , version 1
Pierre-Alexandre Bliman. Lyapunov Equation for the Stability of 2-D Systems. [Research Report] RR-4014, INRIA. 2000. ⟨inria-00072627⟩
39 Consultations
253 Téléchargements
