A Fully Discrete Approximation for Control Problems governed by Parabolic Variational Inequalities
In this work we consider a numerical approximation of an optimal control problem governed by variational inequalities. We use a total discretization scheme: implicit Euler discretization with respect to the time variable and finite element method for the space variable, and give convergence results.
