Blind Ring Signatures Secure under the Chosen-Target-CDH Assumption - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Blind signatures are a useful ingredient to design secure sophisticated systems like electronic voting or sensitive applications like e-cash. Multi-users signature schemes, like ring or group signatures, are also a useful tool to provide to such systems some properties like scalability, anonymity, (dynamic) group structure, revocation facilities... We propose in this article a simple blind ring signature scheme based on pairings on algebraic curves. We formally prove the security (anonymity, blindness and unforgeability) of our scheme in the random oracle model, under quite standard assumptions.
BRS_ISC06.pdf (147.76 Ko) Télécharger le fichier
inria-00072853 , version 1 (24-05-2006)
  • HAL Id : inria-00072853 , version 1
Javier Herranz, Fabien Laguillaumie. Blind Ring Signatures Secure under the Chosen-Target-CDH Assumption. 9th Information Security Conference (ISC'06), Aug 2006, Samos - Greece. ⟨inria-00072853⟩
235 Consultations
471 Téléchargements
