Multimodal Brain Warping Using the Demons Algorithm and Adaptative Intensity Corrections - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1999
Alexis Roche
  • Fonction : Auteur
Nicholas Ayache
Jean Meunier
  • Fonction : Auteur
This paper presents an original method for three-dimensional elastic registrat- ion of multimodal images. We propose to make use of a scheme that iterates between correcting for intensity differences between images and performing standard monomodal registration. The core of our contribution resides in providing a method that finds the transformation that maps the intensities of one image to those of another. It makes the assumption that there are at most two functional dependences between the intensities of structures present in the images to register, and relies on robust estimation techniques to evaluate these functions. We provide results showing successful registratio- n between several imaging modalities involving segmentations, T1 magnetic resonance (MR), T2 MR, proton density (PD) MR and computed tomography (CT). We also argue that our intensity modeling may be more appropriate than mutual information (MI) in the context of evaluating high-dimensional deformations, as it puts more constraints on the parameters to be estimated and thus permits a better search of the parameter space.
RR-3796.pdf (998 Ko) Télécharger le fichier
inria-00072863 , version 1 (24-05-2006)
  • HAL Id : inria-00072863 , version 1
Alexandre Guimond, Alexis Roche, Nicholas Ayache, Jean Meunier. Multimodal Brain Warping Using the Demons Algorithm and Adaptative Intensity Corrections. RR-3796, INRIA. 1999. ⟨inria-00072863⟩
168 Consultations
192 Téléchargements
