Semidefinite Relaxations and Lagrangian Duality with Application to Combinatorial Optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1999
Claude Lemaréchal
  • Fonction : Auteur
  • PersonId : 833553
We show that it is fruitful to dualize the integrality constraints in a combinatorial optimization problem. First, this reproduces the known SDP relaxations of the max-cut and max-stable problems. Then we apply the approach to general combinatorial problems. We show that the resulting duality gap is smaller than with the classical Lagrangian relaxation; we also show that linear constraints need a special treatment.
RR-3710.pdf (376.13 Ko) Télécharger le fichier
inria-00072958 , version 1 (24-05-2006)
  • HAL Id : inria-00072958 , version 1
Claude Lemaréchal, François Oustry. Semidefinite Relaxations and Lagrangian Duality with Application to Combinatorial Optimization. [Research Report] RR-3710, INRIA. 1999. ⟨inria-00072958⟩
656 Consultations
547 Téléchargements
