Numerical Solution of Optimization Test-Cases by Genetic Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1999
In this report, we present the numerical solution of four optimization problems by Genetic Algorithms (GAs). The test-cases involve two single-object- ive and two multi-objective optimization problems. In all four cases, the analytical functions to be optimized present a large number of local optima and the GA is demonstrated to be the most adequate optimizer. These four test-cases are part of the database developed within the INGENET European thematic network.
RR-3622.pdf (2.06 Mo) Télécharger le fichier
inria-00073055 , version 1 (24-05-2006)
  • HAL Id : inria-00073055 , version 1
Nathalie Marco-Blaszka, Jean-Antoine Desideri. Numerical Solution of Optimization Test-Cases by Genetic Algorithms. RR-3622, INRIA. 1999. ⟨inria-00073055⟩
105 Consultations
323 Téléchargements
