Interpreting Functions as pi-calculus Processes: a Tutorial - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1998
This paper is concerned with the relationship between lambda-calculus and pi-calculus. The lambda-calculus talks about \emph{functions} and their\emph{applicative} behaviour. This contrasts with the pi-calculus, that talks aboutemph{processes} and their \emph{interactive} behaviour. Application is a special form of interaction, and therefore functions can be seen as a special form of processes. We study how the functions of the lambda-calculus (the \emph{computable} functions) can be represented as pi-calculus processes. The pi-calculus semantics of a language induces a notion of equality on the terms of that language. We therefore also analyse the equality among functions that is induced by their representation as pi-calculus processes. This paper is intended as a tutorial. It however contains some original contributions. The main ones are: the use of well-known \emph{Continuation Passing Style} transforms to derive the encodings into pi-calculus and prove their correctness; the encoding of \emph{typed} lambda-calculi.
RR-3470.pdf (724.65 Ko) Télécharger le fichier
inria-00073220 , version 1 (24-05-2006)
  • HAL Id : inria-00073220 , version 1
Davide Sangiorgi. Interpreting Functions as pi-calculus Processes: a Tutorial. RR-3470, INRIA. 1998. ⟨inria-00073220⟩
165 Consultations
509 Téléchargements
