An Elementary Approach to Filtering in Systems with Fractional Brownian Observation Noise - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1998
M.L. Kleptsyna
A. Le Breton
  • Fonction : Auteur
M. C. Roubaud
The problem of optimal filtering is addressed for a signal observed through a possibly nonlinear channel driven by a fractional Brownian motion. An elementary and completely self-contained approach is developed. An appropriate Girsanov type result is proved and a process -- equivalent to the innovation process in the usual situation where the observation noise is a Brownian motion -- is introduced. Zakai's approach is partly extended to derive filtering equations when the signal process is a diffusion. The case of conditionally Gaussian linear systems is analyzed. Closed form equations are derived both for the mean of the optimal filter and the conditional variance of the filtering error. The results are explicit in various special cases.
RR-3439.pdf (335.28 Ko) Télécharger le fichier
inria-00073251 , version 1 (24-05-2006)
  • HAL Id : inria-00073251 , version 1
M.L. Kleptsyna, A. Le Breton, M. C. Roubaud. An Elementary Approach to Filtering in Systems with Fractional Brownian Observation Noise. RR-3439, INRIA. 1998. ⟨inria-00073251⟩
63 Consultations
315 Téléchargements
