The Complete Analysis of a Polynomial Factorization Algorithm over Finite Fields - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1998
Philippe Flajolet
  • Fonction : Auteur
  • PersonId : 829512
Xavier Gourdon
  • Fonction : Auteur
Daniel Panario
  • Fonction : Auteur
A unified treatment of parameters relevant to factoring polynomials over finite fields is given. The framework is based on generating functions for describing parameters of interest and on singularity analysis for extracting asymptotic values. An outcome is a complete analysis of the standard polynomial factorization chain that is based on elimination of repeated factors, distinct degree factorization, and equal degree separation. Several basic statistics on polynomials over finite fields are obtained in the course of the analysis.
Autre [cs.OH]
RR-3370.pdf (508.73 Ko) Télécharger le fichier
inria-00073319 , version 1 (24-05-2006)
  • HAL Id : inria-00073319 , version 1
Philippe Flajolet, Xavier Gourdon, Daniel Panario. The Complete Analysis of a Polynomial Factorization Algorithm over Finite Fields. [Research Report] RR-3370, INRIA. 1998. ⟨inria-00073319⟩
75 Consultations
209 Téléchargements
