Newton Method in 3-Dimensional Shape Optimization Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1998
Our goal is to introduce a Newton method to compute the stationary points of a total energy with respect to the shape. We produce a precise description of the second order shape derivative which is given by a symmetrical boundary integral operator, useful for numerical calculations. We apply this method to a particular shape optimization problem, the electromagnetic casting problem. The algorithm to compute the shape gradient and the shape Hessian is adap­ted to a MIMD computer with distributed memory using M.P.I. message passing interface.
Autre [cs.OH]
RR-3367.pdf (575.44 Ko) Télécharger le fichier
inria-00073322 , version 1 (24-05-2006)
  • HAL Id : inria-00073322 , version 1
Arian Novruzi, Jean R. Roche. Newton Method in 3-Dimensional Shape Optimization Problems. [Research Report] RR-3367, INRIA. 1998, pp.33. ⟨inria-00073322⟩
84 Consultations
174 Téléchargements
