An Elementary Proof of the Equivalence between 2D and 3D Classical Snakes and Geodesic Active Contours - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1998
Laure Blanc-Féraud
Recently, Caselles et al. have shown in the equivalence between a classical snake problem of Kass et al. and a geodesic active contour model. The PDE derived from the geodesic problem gives an evolution equation for active contours which is very powerfull for image segmentation since changes of topology are allowed using the level set implementation. However in Caselles' paper the equivalence with classical snake is only shown for 2D images with 1D curves, by using concepts of Hamiltonian theory which have no meanings for active contours. This paper propose a proof using only elementary calculus of mathematical analysis. This proof is also valid in the 3D case for active surfaces.
Autre [cs.OH]
RR-3340.pdf (238.76 Ko) Télécharger le fichier
inria-00073349 , version 1 (24-05-2006)
  • HAL Id : inria-00073349 , version 1
Gilles Aubert, Laure Blanc-Féraud. An Elementary Proof of the Equivalence between 2D and 3D Classical Snakes and Geodesic Active Contours. RR-3340, INRIA. 1998. ⟨inria-00073349⟩
109 Consultations
107 Téléchargements
