A Framework for Parallel Programming in Java
To ease the task of programming parallel and distributed applications, the Do! project aims at the automatic generation of distributed code from multi-threaded Java programs. We provide a parallel programming model, embedded in a framework that constraints parallelism without any extension to the Java language. This framework is described here and is used as a basis to generate distributed programs.
