On Computational Interpretations of the Modal Logic S4 IIIb. Confluence, Termination of the $\lambda\mbox{ev}Q_H$-Calculus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1997
A language of proof terms for minimal logic is the $\lambda$-calculus, where cut-elimination is encoded as $\beta$-reduction. We examine corresponding languages for the minimal version of the modal logic S4, with notions of reduction that encodes cut-elimination for the corresponding sequent system. It turns out that a natural interpretation of the latter constructions is a $\lambda$-calculus extended by an idealized version of Lisp's \verb/eval/ and \verb/quote/ constructs. In this Part~IIIb, we complete the results of Part~IIIa. We show that the typed $\lambda\mbox{ev}Q_H$-calculus is confluent. It follows that the typed $\lambda\mbox{ev}Q_H$-calculus is a conservative extension of the typed ${\lambda_S4}_H$-calculus. We also prove that the typed $\lambda\mbox{ev}Q_H$-calculus is weakly terminating. Some problems remain open. In particular, we still don't know whether the typed $\lambda\mbox{ev}Q$-calculus terminates weakly, or whether the untyped $\lambda\mbox{ev}Q$-calculus is confluent.
RR-3164.pdf (522.71 Ko) Télécharger le fichier
inria-00073524 , version 1 (24-05-2006)
  • HAL Id : inria-00073524 , version 1
Jean Goubault-Larrecq. On Computational Interpretations of the Modal Logic S4 IIIb. Confluence, Termination of the $\lambda\mbox{ev}Q_H$-Calculus. [Research Report] RR-3164, INRIA. 1997. ⟨inria-00073524⟩
134 Consultations
97 Téléchargements
