The Waiting Time Distribution in Poisson-Driven Deterministic Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1997
We consider systems with Poisson arrivals and a deterministic delay structure given by some increasing sequence. We characterize the distribution of waiting times in the transient regime, and describe effective ways to evaluate it. We also compute the stationary waiting time distribution in the case where the deterministic structure becomes ultimately periodic. This analysis is strongly connected to the theory of linear $(\max,+)$ systems and has the same range of applications: we give examples from stochastic Petri Net theory and stochastic task graph theory. It also applies in general to single server queues with Poisson arrivals and known service times, in particular to the $M/D/1$ queue with periodic service durations and the $E/D/1$ queue.
RR-3083.pdf (530.47 Ko) Télécharger le fichier
inria-00073608 , version 1 (24-05-2006)
  • HAL Id : inria-00073608 , version 1
Alain Jean-Marie. The Waiting Time Distribution in Poisson-Driven Deterministic Systems. RR-3083, INRIA. 1997. ⟨inria-00073608⟩
84 Consultations
168 Téléchargements
