Geometric Ergodicity in Hidden Markov Models - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Reports (Research Report) Year : 1996
We consider an hidden Markov model with multidimensional observations, and with misspecification, i.e. the assumed coefficients (transition probability matrix, and observation conditional densities) are possibly different from the true coefficients. Under mild assumptions on the coefficients of both the true and the assumed models, we prove that : (i)~the prediction filter, and its gradient w.r.t. some parameter in the model, forget almost surely their initial condition exponentially fast, and (ii) the extended Markov chain, whose components are : the unobserved Markov chain, the observation sequence, the prediction filter, and its gradient, is geometrically ergodic and has a unique invariant probability distribution.
RR-2991.pdf (441.89 Ko) Télécharger le fichier
Dates and versions
inria-00073706 , version 1 (24-05-2006)
Identifiers
  • HAL Id : inria-00073706 , version 1
Cite
François Le Gland, Laurent Mevel. Geometric Ergodicity in Hidden Markov Models. [Research Report] RR-2991, INRIA. 1996. ⟨inria-00073706⟩
410 View
228 Download
Share
