Iso-surface Extraction in 4D with Applications related to Scale Space - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1996
We present a method for extracting iso-surfaces and their intersections in 4D. Our work is a significant extension of the 3D Marching Lines algorithm with new orientation and implementation considerations. As a practical tool, it can be applied to track efficiently space curves, defined by differential invariants, across increasing scale.
Autre [cs.OH]
RR-2833.pdf (627.96 Ko) Télécharger le fichier
inria-00073858 , version 1 (24-05-2006)
  • HAL Id : inria-00073858 , version 1
Márta Fidrich. Iso-surface Extraction in 4D with Applications related to Scale Space. RR-2833, INRIA. 1996. ⟨inria-00073858⟩
129 Consultations
148 Téléchargements
