Computing Largest Circles Separating Two Sets of Segments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1995
Jean-Daniel Boissonnat
  • Fonction : Auteur
  • PersonId : 830857
Jurek Czyzowicz
  • Fonction : Auteur
Olivier Devillers
Jorge Urrutia
  • Fonction : Auteur
Mariette Yvinec
A circle $C$ separates two planar sets if it encloses one of the sets and its open interior disk does not meet the other set. A separating circle is a largest one if it cannot be locally increased while still separating the two given sets. An $\Theta(n \log n)$ optimal algorithm is proposed to find all largest circles separating two given sets of line segments when line segments are allow ed to meet only at their endpoints. This settles an open problem from a previous paper\cite{bcdy-csp-95}. In the general case, when line segments may intersect $Ømega(n^2)$ times, our algorithm can be adapted to work in $O(n \alpha(n) \log n)$ time and $O(n \alpha(n))$ space, where $\alpha(n)$ represents the extremely slowly growing inverse of Ackermann function.
Autre [cs.OH]
RR-2705.pdf (232.99 Ko) Télécharger le fichier
inria-00073985 , version 1 (24-05-2006)
  • HAL Id : inria-00073985 , version 1
Jean-Daniel Boissonnat, Jurek Czyzowicz, Olivier Devillers, Jorge Urrutia, Mariette Yvinec. Computing Largest Circles Separating Two Sets of Segments. RR-2705, INRIA. 1995. ⟨inria-00073985⟩
99 Consultations
129 Téléchargements
