Parameter Estimation Techniques: A Tutorial with Application to Conic Fitting - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1995
Almost all problems in computer vision are related in one form or another to the problem of estimating parameters from noisy data. In this tutorial, we present what is probably the most commonly used techniques for parameter estimation. These include linear least-squares (pseudo-inverse and eigen analysis); orthogonal least-squares; gradient-weighted least-squares; bias-corrected renormalization; Kalman filtering; and robust techniques (clustering, regression diagnostics, M-estimators, least median of squares). Particular attention has been devoted to discussions about the choice of appropriate minimization criteria and the robustness of the different techniques. Their application to conic fitting is described.
Autre [cs.OH]
RR-2676.pdf (358.97 Ko) Télécharger le fichier
inria-00074015 , version 1 (08-06-2012)
  • HAL Id : inria-00074015 , version 1
Zhengyou Zhang. Parameter Estimation Techniques: A Tutorial with Application to Conic Fitting. [Research Report] RR-2676, INRIA. 1995. ⟨inria-00074015⟩
461 Consultations
7100 Téléchargements
