An Experimental User Level Implementation of TCP - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1995
Christophe Diot
  • Fonction : Auteur
Anna Hoglander
  • Fonction : Auteur
Vincent Roca
With high speed networks supporting data rates of a few hundreds Mbps and distributed applications demanding high performance, existing communication system and protocol architectures are under discussion. In this report, we describe an implementation of the TCP/IP stack with TCP [1] in user space and IP in kernel space. The goal by placing TCP in user space is to obtain a flexible transport protocol which can in future allows integrated communication subsystems based on Application Level Framing (ALF) and Integrated Layer Processing (ILP) [2]. ALF and ILP are expected to achieve more efficient data transfer, and more application control in the communication process.
Autre [cs.OH]
RR-2650.pdf (122.45 Ko) Télécharger le fichier
inria-00074040 , version 1 (24-05-2006)
  • HAL Id : inria-00074040 , version 1
Torsten Braun, Christophe Diot, Anna Hoglander, Vincent Roca. An Experimental User Level Implementation of TCP. RR-2650, INRIA. 1995. ⟨inria-00074040⟩
237 Consultations
846 Téléchargements
