Lambda-Calculus, Combinators and the Comprehension Scheme - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1995
The presentations of type theory based on a comprehension scheme and on $\lambda$-calculus are equivalent, both in the sense that the latter is a conservative extension of the former and that it can be encoded into it preserving provability. A similar result holds for set theory. A short version of this paper appeared in the proceedings of the conference {\it Typed Lambda-calculi and Applications (1995)}.}
Autre [cs.OH]
RR-2565.pdf (284.35 Ko) Télécharger le fichier
inria-00074116 , version 1 (24-05-2006)
  • HAL Id : inria-00074116 , version 1
Gilles Dowek. Lambda-Calculus, Combinators and the Comprehension Scheme. [Research Report] RR-2565, INRIA. 1995. ⟨inria-00074116⟩
68 Consultations
181 Téléchargements
