Convex Tours of Bounded Curvature - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1994
We consider the motion planning problem for a point constrained to move along a smooth closed convex path of bounded curvature. The workspace of the moving point is bounded by a convex polygon with $m$ vertices, containing an obstacle in a form of a simple polygon with $n$ vertices. We present an $O(m+n)$ time algorithm finding the path, going around the obstacle, whose curvature is the smallest possible.
Autre [cs.OH]
RR-2375.pdf (274.25 Ko) Télécharger le fichier
inria-00074301 , version 1 (24-05-2006)
  • HAL Id : inria-00074301 , version 1
Jean-Daniel Boissonnat, Jurek Czyzowicz, Olivier Devillers, Jean-Marc Robert, Mariette Yvinec. Convex Tours of Bounded Curvature. [Research Report] RR-2375, INRIA. 1994. ⟨inria-00074301⟩
119 Consultations
133 Téléchargements
