Tailored Protocol Development Using ESTEREL - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1994
The rapid evolution of networking and the multiplication of new applications re-emphasizes the importance of the efficient communication supports. Implementations must be able to take maximal advantage of the details of application-specific semantics and of specific networking environments. In other words, the application needs to have more control over data transmission. Such control can be obtained by tailoring the communication facilities (or protocols) to the application characteritics, and by integrating the communication control to the application. Because such a task is too complex to be realized manually, we propose to automate the protocol development process using a formal approach. This report presents our approach to the automated design and implementation of application- specific communication protocols based on information provided by the application. Starting from the formal description of an application, our approach is based on a tool called "Protocol Compiler" that will automatically produce the implementation of a communication protocol tailored to the application. The formalism we use is ESTEREL, a synchronous reactive language dedicated to the description of real-time systems. Protocol description and verification using ESTEREL are described, as well as protocol optimization and implementation principles.
Autre [cs.OH]
RR-2374.pdf (288.65 Ko) Télécharger le fichier
inria-00074302 , version 1 (24-05-2006)
  • HAL Id : inria-00074302 , version 1
Claude Castelluccia, Isabelle Chrisment, Walid Dabbous, Christophe Diot, Christian Huitema, et al.. Tailored Protocol Development Using ESTEREL. [Research Report] RR-2374, INRIA. 1994. ⟨inria-00074302⟩
85 Consultations
194 Téléchargements
