Incremental algorithms for finding the convex hulls of circles and the lower envelopes of parabolas - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1994
The existing $O(n \log n)$ algorithms for finding the convex hulls of circles and the lower envelope of parabolas follow the divide-and-conquer paradigm. The difficulty with developing incremental algorithms for these problems is that the introduction of a new circle or parabola can cause $\Theta(n)$ structural changes, leading to $\Theta(n^2)$ total structural changes during the running of the algorithm. In this note we examine the geometry of these problems and show that, if the circles or parabolas are first sorted by appropriate parameters before constructing the convex hull or lower envelope incrementally, then each new addition may cause at most 3 changes in an amortized sense. These observations are then used to develop $O(n \log n)$ incremental algorithms for these problems.
Autre [cs.OH]
RR-2280.pdf (248.43 Ko) Télécharger le fichier
inria-00074391 , version 1 (24-05-2006)
  • HAL Id : inria-00074391 , version 1
Olivier Devillers, Mordecai Golin. Incremental algorithms for finding the convex hulls of circles and the lower envelopes of parabolas. [Research Report] RR-2280, INRIA. 1994. ⟨inria-00074391⟩
404 Consultations
3137 Téléchargements
