On topology in multidimensional discrete - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 1993
Grégoire Malandain
To study topology in digital binary images, different discrete connectivities have to be used for both the object and the background. We prove equivalences between discrete connectivities, as they are usually defined in a digital space and connectivity in a continuous space. For that purpose, we introduce the notion of regularization of a set of voxels. It will permit us to define continuous sets from discrete ones. We discuss then the choice of a good couple of discrete connectivities for both the object and the background and provide a characterization of such a valid pair. Finally, we use our best choice to demonstrate a separation theorem in dimension n for surfaces made of voxels.
Autre [cs.OH]
RR-2098.pdf (260.46 Ko) Télécharger le fichier
inria-00074574 , version 1 (24-05-2006)
  • HAL Id : inria-00074574 , version 1
Grégoire Malandain. On topology in multidimensional discrete. RR-2098, INRIA. 1993. ⟨inria-00074574⟩
69 Consultations
89 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
