A Complete and efficient algorithm for the intersection of a general ans a convex polyhedron - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1993
A polyhedron is any set that can be obtained from the open halfspaces by a finite number of set complement and set intersection operations. We give an efficient and complete algorithm for intersecting two three-dimensional polyhedra, one of which is convex. The algorithm is efficient in the sense that its running time is bounded by the size of the inputs plus the size of the output times a logarithmic factor. The algorithm is complete in the sense that it can handle all inputs and requires no general position assumption. We also describe a novel data structure that can represent all three-dimensional polyhedra (the set of polyhedra representable by all previous data structures is not closed under the basic boolean operations).
Autre [cs.OH]
RR-2023.pdf (278.27 Ko) Télécharger le fichier
inria-00074648 , version 1 (24-05-2006)
  • HAL Id : inria-00074648 , version 1
Katrin Dobrindt, Kurt Mehlhorn, Mariette Yvinec. A Complete and efficient algorithm for the intersection of a general ans a convex polyhedron. [Research Report] RR-2023, INRIA. 1993. ⟨inria-00074648⟩
215 Consultations
1576 Téléchargements
