A list-machine benchmark for mechanized metatheory - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
We propose a benchmark to compare theorem-proving systems on their ability to express proofs of compiler correctness. In contrast to the first POPLmark, we emphasize the connection of proofs to compiler implementations, and we point out that much can be done without binders or alpha-conversion. We propose specific criteria for evaluating the utility of mechanized metatheory systems; we have constructed solutions in both Coq and Twelf metatheory, and we draw conclusions about those two systems in particular.
RR-5914.pdf (413.74 Ko) Télécharger le fichier
inria-00077531 , version 1 (31-05-2006)
  • HAL Id : inria-00077531 , version 1
Andrew W. W. Appel, Xavier Leroy. A list-machine benchmark for mechanized metatheory. [Research Report] RR-5914, INRIA. 2006. ⟨inria-00077531⟩
200 Consultations
212 Téléchargements
