Formal verification of a memory model for C-like imperative languages - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
This paper presents a formal verification with the Coq proof assistant of a memory model for C-like imperative languages. This model defines the memory layout and the operations that manage the memory. The model has been specified at two levels of abstraction and implemented as part of an ongoing certification in Coq of a moderately-optimising C compiler. Many properties of the memory have been verified in the specification. They facilitate the definition of precise formal semantics of C pointers. A certified OCaml code implementing the memory model has been automatically extracted from the specifications.
icfem05Blazy.pdf (541.55 Ko) Télécharger le fichier
inria-00077921 , version 1 (01-06-2006)
Sandrine Blazy, Xavier Leroy. Formal verification of a memory model for C-like imperative languages. ICFEM'05: 7th International Conference on Formal Engineering Methods, Nov 2005, Manchester, United Kingdom. pp.280-299, ⟨10.1007/11576280⟩. ⟨inria-00077921⟩
233 Consultations
207 Téléchargements
