Emulation of a FMA and correctly-rounded sums: proved algorithms using rounding to odd - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2006
Sylvie Boldo
Guillaume Melquiond
Rounding to odd is a non-standard rounding on floating-point numbers. By using it for some intermediate values instead of rounding to nearest, correctly rounded results can be obtained at the end of computations. We present an algorithm to emulate the fused multiply-and-add operator. We also present an iterative algorithm for computing the correctly rounded sum of a set floating-point numbers under mild assumptions. A variation on both previous algorithms is the correctly rounded sum of any three floating-point numbers. This leads to efficient implementations, even when this rounding is not available. In order to guarantee the correctness of these properties and algorithms, we formally proved them using the Coq proof checker.
odd-rounding.pdf (173.97 Ko) Télécharger le fichier
inria-00080427 , version 1 (16-06-2006)
inria-00080427 , version 2 (10-11-2010)
  • HAL Id : inria-00080427 , version 1
Sylvie Boldo, Guillaume Melquiond. Emulation of a FMA and correctly-rounded sums: proved algorithms using rounding to odd. 2006. ⟨inria-00080427v1⟩
2988 Consultations
7039 Téléchargements
