Global Stabilization of a Class of Partially Known Positive Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
In this report we deal with the problem of global output feedback stabilization of a class of $n$-dimensional nonlinear positive systems possessing a one-dimensional unknown, though measured, part. We first propose our main result, an output feedback control procedure, taking advantage of measurements of the uncertain part, able to globally stabilize the system towards an adjustable equilibrium point in the interior of the positive orthant. Though quite general, this result is based on hypotheses that might be difficult to check in practice. Then in a second step, through a Theorem on a class of positive systems linking the existence of a strongly positive equillibrium to its global asymptotic stability, we propose other hypotheses for our main result to hold. These new hypotheses are more restrictive but much simpler to check. Some illustrative examples, highlighting both the potential complex open loop dynamics (multi-stability, limit cycle, chaos) of the considered systems and the interest of the control procedure, conclude this report.
RR_mailleret_gouze_bernard.pdf (886.71 Ko) Télécharger le fichier
inria-00086788 , version 1 (19-07-2006)
inria-00086788 , version 2 (28-07-2006)
Jean-Luc Gouzé, Olivier Bernard, Ludovic Mailleret. Global Stabilization of a Class of Partially Known Positive Systems. [Research Report] 2006. ⟨inria-00086788v1⟩
196 Consultations
113 Téléchargements
