On the Minimization of {XML}-Schemas and Tree Automata for Unranked Trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computer and System Sciences Année : 2006
Automata for unranked trees form a foundation for XML schemas, querying and pattern languages. We study the problem of efficiently minimizing such automata. First, we study unranked tree automata that are standard in database theory, assuming bottom-up determinism and that horizontal recursion is represented by deterministic finite automata. We show that minimal automata in that class are not unique and that minimization is np complete. Second, we study more recent automata classes that do allow for polynomial time minimization. Among those, we show that bottom-up deterministic stepwise tree automata yield the most succinct representations. Third, we investigate abstractions of ML schema languages. In particular, we show that the class of one-pass preorder typable schemas allows for polynomial time minimization and unique minimal models.
mini.pdf (426.97 Ko) Télécharger le fichier
inria-00088406 , version 1 (01-08-2006)
inria-00088406 , version 2 (13-08-2006)
  • HAL Id : inria-00088406 , version 1
Wim Martens, Joachim Niehren. On the Minimization of {XML}-Schemas and Tree Automata for Unranked Trees. Journal of Computer and System Sciences, 2006, Journal of Computer and System Science. ⟨inria-00088406v1⟩
205 Consultations
324 Téléchargements
