Coalescent tree based functional representations for some Feynman-Kac particle models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
We design a theoretic tree-based functional representation of a class of Feynman-Kac particle distributions, including an extension of the Wick product formula to interacting particle systems. These weak expansions rely on an original combinatorial, and permutation group analysis of a special class of forests. They provide refined non asymptotic propagation of chaos type properties, as well as sharp Lp-mean error bounds, and laws of large numbers for U-statistics. Applications to particle interpretations of the top eigenvalues, and the ground states of Schrödinger semigroups are also discussed.
rr-xxxx.pdf (554.25 Ko) Télécharger le fichier
inria-00090242 , version 1 (29-08-2006)
inria-00090242 , version 2 (05-09-2006)
  • HAL Id : inria-00090242 , version 1
Pierre del Moral, Frédéric Patras, Sylvain Rubenthaler. Coalescent tree based functional representations for some Feynman-Kac particle models. [Research Report] 2006, pp.45. ⟨inria-00090242v1⟩
200 Consultations
134 Téléchargements
