Perturbations and Vertex Removal in Delaunay and Regular 3D Triangulations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
Olivier Devillers
Monique Teillaud
Though Delaunay and regular triangulations are very well known geometric data structures, the problem of the robust removal of a vertex in a three-dimensional triangulation is actually a problem in practice. We propose a simple method that allows to remove any vertex even when the points are in very degenerate configurations. The solution is available in CGAL (www.cgal.org).
RR.pdf (251.17 Ko) Télécharger le fichier
inria-00090522 , version 1 (31-08-2006)
inria-00090522 , version 2 (04-09-2006)
  • HAL Id : inria-00090522 , version 1
Olivier Devillers, Monique Teillaud. Perturbations and Vertex Removal in Delaunay and Regular 3D Triangulations. [Research Report] 2006, pp.11. ⟨inria-00090522v1⟩
306 Consultations
196 Téléchargements
