Circular Cylinders by Four or Five Points in Space - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete and Computational Geometry Année : 2002
Olivier Devillers
Bernard Mourrain
Philippe Trebuchet
  • Fonction : Auteur
  • PersonId : 833470
We are interested in computing effectively cylinders through 5 points, and in other problems involved in metrology. In particular, we consider the cylinders through 4 points with a fix radius and with extremal radius. For these different problems, we give bounds on the number of solutions and exemples show that these bounds are optimal. Finally, we describe two algebraic methods which can be used here to solve efficiently these problems and some experimentation results.
dcg.pdf (372 Ko) Télécharger le fichier
inria-00090648 , version 1 (01-09-2006)
Olivier Devillers, Bernard Mourrain, Franco P. Preparata, Philippe Trebuchet. Circular Cylinders by Four or Five Points in Space. Discrete and Computational Geometry, 2002, 29 (1), pp.83--104. ⟨10.1007/s00454-002-2811-7⟩. ⟨inria-00090648⟩
232 Consultations
542 Téléchargements
