Splitting a Delaunay Triangulation in Linear Time - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Algorithmica Année : 2002
Computing the Delaunay triangulation of n points requires usually a minimum of Omega(n log n) operations, but in some special cases where some additional knowledge is provided, faster algorithms can be designed. Given two sets of points, we prove that, if the Delaunay triangulation of all the points is known, the Delaunay triangulation of each set can be computed in randomized expected linear time.
algorithmica.pdf (122.75 Ko) Télécharger le fichier
inria-00090664 , version 1 (01-09-2006)
Bernard Chazelle, Olivier Devillers, Ferran Hurtado, Mercè Mora, Vera Sacristan, et al.. Splitting a Delaunay Triangulation in Linear Time. Algorithmica, 2002, 34 (1), pp.39--46. ⟨10.1007/s00453-002-0939-8⟩. ⟨inria-00090664⟩
151 Consultations
390 Téléchargements
