Hoàng-Reed conjecture holds for tournaments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
Hoàng-Reed conjecture asserts that every digraph $D$ has a collection $\cal C$ of circuits $C_1,\dots,C_{\delta ^+}$, where $\delta ^+$ is the minimum outdegree of $D$, such that the circuits of $\cal C$ have a forest-like structure. Formally, $|V(C_i)\cap (V(C_1)\cup \dots \cup V(C_{i-1}))|\leq 1$, for all $i=2,\dots ,\delta^+$. We verify this conjecture for the class of tournaments.
RR-5976.pdf (226.32 Ko) Télécharger le fichier
inria-00091366 , version 1 (06-09-2006)
inria-00091366 , version 2 (15-09-2006)
  • HAL Id : inria-00091366 , version 2
Frédéric Havet, Stéphan Thomassé, Anders Yeo. Hoàng-Reed conjecture holds for tournaments. [Research Report] RR-5976, INRIA. 2006, pp.7. ⟨inria-00091366v2⟩
138 Consultations
212 Téléchargements
