Stochastic Differential Equations Driven by Processes Generated by Divergence Form Operators II: Convergence results - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Probability and Statistics Année : 2006
We have seen in a previous article how the theory of "rough paths" allows us to construct solutions of differential equations driven by processes generated by divergence form operators. In this article, we study a convergence criterion which implies that one can interchange the integral with the limit of a family of stochastic processes generated by divergence form operators. As a corollary, we identify stochastic integrals constructed with the theory of rough paths with Stratonovich or Itô integrals already constructed for stochastic processes generated by divergence form operators by using time-reversal techniques.
lejay-SDE-opdiv-2-corr-2.pdf (390.73 Ko) Télécharger le fichier
inria-00092427 , version 1 (10-09-2006)
inria-00092427 , version 2 (06-12-2006)
inria-00092427 , version 3 (05-06-2007)
Antoine Lejay. Stochastic Differential Equations Driven by Processes Generated by Divergence Form Operators II: Convergence results. ESAIM: Probability and Statistics, 2006, 10, pp.356-375. ⟨10.1051/ps:2006015⟩. ⟨inria-00092427v2⟩
546 Consultations
295 Téléchargements
