Tutorial on the event-based B method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Cours Année : 2006
B is a method for specifying, designing and coding software systems. It is based on Zermelo-Fraenkel set theory with the axiom of choice, the concept of generalized substitution and on structuring mechanisms (machine,refinement, implementation). The concept of refinement is the key notion for developing B models of (software) systems in an incremental way. B models are accompanied by mathematical proofs that justify them. Proofs of B models convince the user (designer or specifier) that the (software) system is effectively correct. We provide a survey of the underlying logic of the B method and the semantic concepts related to the B method; we detail the B development process partially supported by the mechanical engine of the prover.
tutorialforte2006mery.pdf (562.04 Ko) Télécharger le fichier
inria-00092846 , version 1 (13-09-2006)
  • HAL Id : inria-00092846 , version 1
Dominique Cansell, Dominique Méry. Tutorial on the event-based B method. IFIP FORTE 2006 Paris, 2006. ⟨inria-00092846⟩
606 Consultations
7373 Téléchargements
