Meshing Volumes Bounded by Smooth Surfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
This paper introduces a three-dimensional mesh generation algorithm for domains bounded by smooth surfaces. The algorithm combines a Delaunay-based surface mesher with a Ruppert-like volume mesher, to get a greedy algorithm that samples the interior and the boundary of the domain at once. The algorithm constructs provably-good meshes, it gives control on the size of the mesh elements through a user-defined sizing field, and it guarantees the accuracy of the approximation of the domain boundary. A noticeable feature is that the domain boundary has to be known only through an oracle that can tell whether a given point lies inside the object and whether a given line segment intersects the boundary. This makes the algorithm generic enough to be applied to a wide variety of objects, ranging from domains defined by implicit surfaces to domains defined by level-sets in 3D grey-scaled images or by point-set surfaces.
volmesh-hal.pdf (923.82 Ko) Télécharger le fichier
inria-00097841 , version 1 (22-09-2006)
  • HAL Id : inria-00097841 , version 1
Steve Oudot, Laurent Rineau, Mariette Yvinec. Meshing Volumes Bounded by Smooth Surfaces. International Meshing Roundtable, 2005, San Diego, Californie, USA. ⟨inria-00097841⟩
158 Consultations
191 Téléchargements
