A Fuzzy-Logic and Multi-Layer Perceptron Hybrid Model Applied to a Real World Steel-Making Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1998
Yannick Lallement
  • Fonction : Auteur
  • PersonId : 757090
  • IdRef : 174648871
Frédéric Alexandre
The most interesting properties of neuro-symbolic hybrid models is that they can allow for the combination of knowledge-based and data-based approaches. We have used such a strategy in a large, complex steel-making problem. We present this problem together with one of the hybrid models that have been tested on it. We chose to fully describe this hybrid because it is representative of such data-knowledge integration properties.
Autre [cs.OH]
98-R-084.pdf (83.09 Ko) Télécharger le fichier
inria-00098693 , version 1 (26-09-2006)
  • HAL Id : inria-00098693 , version 1
Yannick Lallement, Frédéric Alexandre. A Fuzzy-Logic and Multi-Layer Perceptron Hybrid Model Applied to a Real World Steel-Making Problem. International Conference on Neural Networks and their Applications, 1998, Marseille, France, pp.399-402. ⟨inria-00098693⟩
60 Consultations
43 Téléchargements
