Convexifying Monotone Polygons
This paper considers reconfigurations of polygons, where each polygon edge is a rigid link, no two of which can cross during the motion. We prove that one can reconfigure any monotone polygon into a convex polygon; a polygon is monotone if any vertical line intersects the interior at a (possibly empty) interval. Our algorithm computes in O(n2) time a sequence of O(n2) moves, each of which rotates just four joints at once.
Autre [cs.OH]
