On the worst-case complexity of the silhouette of a polytope - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
We give conditions under which the worst-case size of the silhouette of a polytope is sub-linear. We provide examples with linear size silhouette if any of these conditions is relaxed. Our bounds are the first non-trivial bounds for the worst-case complexity of silhouettes.
Autre [cs.OH]
A03-R-081.pdf (232.28 Ko) Télécharger le fichier
inria-00099478 , version 1 (26-09-2006)
  • HAL Id : inria-00099478 , version 1
Helmut Alt, Marc Glisse, Xavier Goaoc. On the worst-case complexity of the silhouette of a polytope. 15th Canadian Conference on Computational Geometry - CCCG 2003, 2003, Halifax, Canada, 4 p. ⟨inria-00099478⟩
135 Consultations
41 Téléchargements
