Study of the impact of asymmetry and carrier sense mechanism in IEEE 802.11 multi-hops networks through a basic case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
This article presents a theoretical modeling of a small but characteristic scenario that shows a great inequity in medium access between nodes using the IEEE 802.11 DCF mode. In his configuration, two terminals evolve independently and are almost never synchronized, which results in a serious performance issue for a third emitter in between. The results are compared to simulation results and are followed by a discussion on the different performance loss causes.
Fichier non déposé
inria-00100142 , version 1 (26-09-2006)
  • HAL Id : inria-00100142 , version 1
Claude Chaudet, Isabelle Guérin Lassous, Eric Thierry, Bruno Gaujal. Study of the impact of asymmetry and carrier sense mechanism in IEEE 802.11 multi-hops networks through a basic case. Proceedings of the First ACM Workshop on Performance Evaluation of Wireless Ad Hoc, Sensor, and Ubiquitous Networks - PE-WASUN'2004, Oct 2004, Venice/Italy, 7 p. ⟨inria-00100142⟩
166 Consultations
0 Téléchargements
