A resultant approach to detect intersecting curves in the projective space - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
Laurent Busé
André Galligo
  • Fonction : Auteur
  • PersonId : 835184
Given two curves in the projective space, either implicitly or by a parameterization, we want to check if they intersect. For that purpose, we present and further develop generalized resultant techniques. Our aim is to provide a closed formula in the inputs which vanishes if and only if the two curves intersect. This could be useful in Computer Aided Design, for computing the intersection of algebraic surfaces.
subBuseGal.pdf (264.68 Ko) Télécharger le fichier
inria-00100315 , version 1 (26-09-2006)
  • HAL Id : inria-00100315 , version 1
Laurent Busé, André Galligo. A resultant approach to detect intersecting curves in the projective space. MEGA 2003, Jun 2003, Kaiserslautern, Germany. ⟨inria-00100315⟩
202 Consultations
116 Téléchargements
