An Introduction to Rough Paths - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2003
This article aims to be an introduction to the theory of rough paths, in which integrals of differential forms against irregular paths and differential equations controlled by irregular paths are defined. This theory makes use of an extension of the notion of iterated integrals of the paths, whose algebraic properties appear to be fundamental. This theory is well-suited for stochastic processes.
introduction_to_rough_paths_SemP_LNM_1832.pdf (483.62 Ko) Télécharger le fichier
inria-00102184 , version 1 (25-02-2009)
Antoine Lejay. An Introduction to Rough Paths. J. Azéma; M. Ledoux; M. Emery; M. Yor. Seminaire de Probabilités XXXVII, 1832 (1832), Springer Berlin / Heidelberg, pp.1-59, 2003, Lecture Notes in Mathematics, 978-3-540-20520-3. ⟨10.1007/b94376⟩. ⟨inria-00102184⟩
298 Consultations
8984 Téléchargements
