Helly-Type Theorems for Line Transversals to Disjoint Unit Balls - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete and Computational Geometry Année : 2008
We prove Helly-type theorems for line transversals to disjoint unit balls in $\R^{d}$. In particular, we show that a family of $n \geq 2d$ disjoint unit balls in $\R^d$ has a line transversal if, for some ordering $\prec$ of the balls, any subfamily of $2d$ balls admits a line transversal consistent with $\prec$. We also prove that a family of $n \geq 4d-1$ disjoint unit balls in $\R^d$ admits a line transversal if any subfamily of size $4d-1$ admits a transversal.
Helly-for-transversals.pdf (254.27 Ko) Télécharger le fichier
inria-00103856 , version 1 (06-02-2007)
Otfried Cheong, Xavier Goaoc, Andreas Holmsen, Sylvain Petitjean. Helly-Type Theorems for Line Transversals to Disjoint Unit Balls. Discrete and Computational Geometry, 2008, 39 (1-3), pp.194-212. ⟨inria-00103856⟩
104 Consultations
343 Téléchargements
