Markov Random Field Models to Extract The Layout of Complex Handwritten Documents - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Thierry Paquet
Laurent Heutte
We consider in this paper the problem of complex handwritten page segmentation such as novelist drafts or authorial manuscripts. We propose to use stochastic and contextual models in order to cope with local spatial variability, and to take into account some prior knowledge about the global structure of the document image. The models we propose to use are Markov Random Field models. Using this model, the segmentation is performed using optimization techniques. Using the MRF framework, the segmentation is equivalent to an image labeling problem and is performed using optimization techniques.
cr1105221077225.pdf (465.25 Ko) Télécharger le fichier
inria-00104788 , version 1 (09-10-2006)
  • HAL Id : inria-00104788 , version 1
Stéphane Nicolas, Thierry Paquet, Laurent Heutte. Markov Random Field Models to Extract The Layout of Complex Handwritten Documents. Tenth International Workshop on Frontiers in Handwriting Recognition, Université de Rennes 1, Oct 2006, La Baule (France). ⟨inria-00104788⟩
105 Consultations
183 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
