A Model-Based Actor-Critic Algorithm in Continuous Time and Space - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
Rémi Coulom
  • Fonction : Auteur
  • PersonId : 836044
This paper presents a model-based actor-critic algorithm in continuous time and space. Two function approximators are used: one learns the policy (the actor) and the other learns the state-value function (the critic). The critic learns with the TD(lambda) algorithm and the actor by gradient ascent on the Hamiltonian. A similar algorithm had been proposed by Doya, but this one is more general. This algorithm was applied successfully to teach simulated articulated robots to swim.
A03-R-125.pdf (76.16 Ko) Télécharger le fichier
inria-00107659 , version 1 (19-10-2006)
  • HAL Id : inria-00107659 , version 1
Rémi Coulom. A Model-Based Actor-Critic Algorithm in Continuous Time and Space. Sixth European Workshop on Reinforcement Learning - EWRL6, Sep 2003, Nancy, France, 2 p. ⟨inria-00107659⟩
129 Consultations
68 Téléchargements
